Activity › Forums › AJA Video Systems › *NEW* AJA KONA 1.2.2 SOFTWARE
  • *NEW* AJA KONA 1.2.2 SOFTWARE
    Posted by Aja Sales department on April 12, 2006 at 12:33 am
    Hello,
    Available immediately at the KONA Support section of our website is a new 1.2.2 version of our KONA driver software. New in This Release:
    – Support added for Final Cut Pro version 5.1
    – For all PCIe Kona Cards (3/LSe/LHe): Fixed Macintosh PCIe computer startup issues when additional 3rd party cards were also installed in the system.
    – For all Kona Cards: Easy Setups Improved.
    Final Cut Pro Version 5.1 Note
    In the setup tab of the Kona Control Panel application is a new checkbox called “Final Cut Pro 5.1+ Compatible”. If you are running Final Cut v5.1 or later, this checkbox should be checked. If this checkbox is not set correctly (off when it should be on, or on when it should be off), the accuracy of captures may be affected.
    This update is recommended for all supported KONA LS/LSe, LH/LHe, KONA 2 and KONA 3 users.
    https://www.aja.com/support_kona.html
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    Aja Sales department replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
