Activity › Forums › AJA Video Systems › NEW AJA Io public beta software available now, Important Info re: FCP5 and Tiger
  • NEW AJA Io public beta software available now, Important Info re: FCP5 and Tiger
    Posted by Aja Sales department on May 24, 2005 at 12:26 am
    Hello-
    *Io product family driver v2.0b1*
    https://www.aja.com/support_Io.html
    This new public beta software is available for Io, Io LA, and Io LD. New features include:
    Reduced latency through Io.
    Note: In order to compensate for this reduced latency you will have to change the Playback Frame Offset in Final Cut Pro HD ( System Settings > Playback Control > Frame Offset ) to a value of “5”.
    Added support for 23.98fps
    Support for Final Cut Pro 5
    Support for OSX 10.4 Tiger
    Increased accuracy of PAL captures
    Improved reliability of Insert Edits to tape
    To install the software
    1. Download the software update from our Io support page
    (https://www.aja.com/support_Io.html).
    2. The file downloaded is a “.zip” archive. Double-click it to expand the archive. The expanded file is a .dmg file. Double-click it.
    3. After double-clicking, you will find a new volume mounted on your Mac desktop. Look on your desktop for the volume named “AJA Io” plus the version number. In the volume window you?ll see separate folders for “Io”, “IoLA” and “IoLD”. Open the folder that corresponds to your Io model.
    4. Inside the folder, locate the installer package files; they have an icon that looks like a box and have a “.mpkg” suffix. There should be a variety of different packages. 5. Out of the packages, choose the ones that best match your operating environment (you can install more than one).
    For example, if the system will be used primarily for working with US NTSC digital video, then select the “IoDigitalNTSC-US.mpkg” file. The file(s) you choose affect the Final Cut Easy Setup presets that will be installed.
    Note: Files ending in the “.pkg” or “.mpkg” suffix are OS X installer files.
    These launch the OS X installer and tell it where and what to install on your
    system.
    This software and more information is available on our Io support page:
    NOTE: If you are currently using an Apple Xserve RAID for your storage, AJA recommends waiting for an update from Apple for the Xserve RAID before you install the latest Io/IoLA/IoLD driver designed for FCP 5 (v2.0b). If you are using some other type of storage for your media, you can use this updated driver now. Also, the 2.0b drivers are beta software, so observe the usual precautions for using beta software: don’t use on critical projects, don’t upgrade in mid-project, keep backups of your project files, and “Save” often. The final release version of this software will be released within the next few
    weeks.
    As always, please contact us if you have any additional questions, to sales@aja.com, (530) 274-2048, or support@aja.com, (530) 271-3190.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    David Massachi replied 21 years, 3 months ago 9 Members · 11 Replies
  • 11 Replies
  • Paul Figgiani
    May 24, 2005 at 12:18 pm
    Installed last eve…all is well.
    Thanks.
    -paul.
  • John Fishback
    May 24, 2005 at 2:11 pm
    Does this driver enable the IO to work with Soundtrack Pro?
    John
    “If you’re not part of the steamroller, you’re part of the road” – Stewart Bland
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA I
  • Aja Sales department
    May 24, 2005 at 4:13 pm
    Hi-
    The new driver support with the newest Apple software supports the VideoOut of Soundtrack Pro, Motion 2, Shake 4, etc.
    Thanks-
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
  • John Fishback
    May 24, 2005 at 4:52 pm
    When will audio in and out be supported?
    John
    FCP4.5 DVDSP 3.0.2
    AJA I
  • Mo Gardner
    May 26, 2005 at 7:48 pm
    I just got AE 6.5, does the Io support any type of output to an NTSC monitor for After Effects?
    … ever forward
  • Tony! Hulette
    May 26, 2005 at 9:05 pm
    [Mo] “I just got AE 6.5, does the Io support any type of output to an NTSC monitor for After Effects?”
    Yes. The Io does support video out from After Effects (it already had this capability with the current drivers).
    Tony!
  • Beelaster
    May 28, 2005 at 6:13 am
    Is the New AJA Io driver for FCP 4.5/Panther users as well?
    G5 dual 2.0/2gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock 5200 video card/Prod Suite/Logic 7.1/Avid Xpress Pro
    May 28, 2005 at 5:34 pm
    Hi-
    Yes, the new 2.0 driver is compatible with FCP 4.5, and OSX 10.3.9. Of course, some of the features discussed about this new driver are FCP5-only, like Multicam support, etc.
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
  • Kevin Gardam
    May 31, 2005 at 9:41 am
    And where do we stand with 4trk input with QT7…AES/embedded.with your latest driver for FCP5,
    within Panther and Tiger.?
    Ta in advance
  • Annaël Beauchemin
    May 31, 2005 at 3:30 pm
    [AJA Sales Department] “Added support for 23.98fps”
    does that mean older drivers cannot *playback* a 23.98 timeline with clips captured with advanced pulldown removal directly from a dvx100?
    Or should I read that we can now use FCP’s advanced pulldown removal when capturing with the io?
    I’m asking because the IO is working fine right now and I will work on a 24PA project soon. If 24PA playback is already supported, I’ll stay with current drivers…
    thx
