Activity › Forums › AJA Video Systems › New AJA card popping on playback
  • New AJA card popping on playback
    Posted by Ross Marshall on January 31, 2006 at 11:55 pm
    At my job I have just made them get rid of an old Avid Media Composer, to get G5 with Final Cut and Kona LH card. Capturing SDI but capturing analoge audio. The problem is on playback when I play the timeline or scrub the timeline the audio pops. All the latest updates are on and apart from that the system seems to work OK.
    Please help.
    Cheers Ross
    Erik Mickelson replied 17 years, 5 months ago 3 Members · 2 Replies
  • Walter Biscardi
    February 3, 2006 at 12:26 pm
    Have you contacted AJA Tech Support?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Erik Mickelson
    April 22, 2009 at 3:50 pm
    Make sure your settings in the Kona Control Panel are the same as your monitor native resolution – no resolution converting allowed. Jeremy Garchow figured this one out a while ago.
    I have an 4:3 NTSC broadcast monitor and converting will always give me pops when I switch aps. If the Kona Control Panel is set to Primary Native Format 525i 29.97 there are no audio issues.
    I only have problems when I am switching between AE and other programs, if I am staying in FCP I can leave the Kona in whatever format I like and there are no problems. Only when I hop around to different programs do I get the pops and clicks and pauses and dropouts…broken record.
    I have contacted AJA about this three times with no response from them. The cow is way better for support than AJA.
    MacPro Dual Core 2 Duo 3.0Ghz, 6GB ram, 1TB Raid, Tiger 10.4.11, FCPStudio 2
