Activity Forums Adobe After Effects New AE/Premiere CS4 Widescreen Ratios
  • New AE/Premiere CS4 Widescreen Ratios
    Posted by Karim Daire on January 17, 2010 at 3:34 pm
    Does anyone have an explanation on why the widescreen square Pixels Ratio was changed from CS3 to CS4 from 1024 pixels width to 1046?
    I mean, every program I know uses 1024 pixels for PAL widescreen comps, so if I import the stuff to e.g. Avid or Final Cut I have to distort the clip to fit an anamorph comp.
    I fail to understand why 2009 needed Adobe to change ratios which were used for years by most video and animation programs?
    Karim
    -Karim-
    Todd Kopriva replied 16 years, 8 months ago 3 Members · 2 Replies
  • Gary Hazen
    January 17, 2010 at 3:54 pm
    The short answer is, for years the numbers have been wrong (due to rounding off) and Adobe finally decided to correct the numbers.
    For the long answer read this:
    https://provideocoalition.com/index.php/cmg_keyframes/story/par_for_the_course/
  • Todd Kopriva
    January 17, 2010 at 5:08 pm
    There’s a terse explanation here.
    Also, see this post for news that Apple has also made these corrections in Final Cut Pro 7.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
