Activity › Forums › Adobe After Effects › New AE6.5 User
New AE6.5 User
Posted by Chris Ives on April 15, 2005 at 8:35 amHelp! Completely new to AE6.5, I want to add a shatter effect to a video clip. I can get the shatter to start at the beginning of the clip, but how do I get the shatter effect to start at, let’s say, 20 seconds into the clip??????
Chris Ives replied 21 years, 5 months ago 4 Members · 8 Replies -
Angus Mackay
April 15, 2005 at 10:15 amHi Chris,
You could split the layer at the point you want the shatter to happen (CTRL/CMND>>SHIFT>>D) and then apply shatter to the second part of the layer.
Angus
Chris Ives
April 15, 2005 at 11:46 amAngus,
THanks for the quick reply!
I’ve tried that, applied the shatter effect to the second half of the clip, but it seems to start already shattered. I’m sure I must be missing something REALLY simple!
Chris
Angus Mackay
April 15, 2005 at 12:24 pmHi Chris
I think you might need to pre-comp the layer first (moving all atributes to new comp). I’ve got an old project open here and that seems to be what I did to get it to work
Angus
Angus Mackay
April 15, 2005 at 12:26 pmOh, and, in case you didn’t know, to pre-comp sleect the relevant layer and CTRL/CMD>>SHIFT>>C will bring up your pre-comp dialogue
HTH
Angus
Chris Ives
April 15, 2005 at 1:33 pmStill no joy! When I add the shatter effect, it’s still coming up with the wireframe and forces in the preview window, with the whole centre (around the ‘wheel’) already shattered.
Scott Spengler
April 15, 2005 at 2:21 pmChris,
You need to animate the depth of the force ball. It defaults to right in the middle of your layer, hence instant shatter. At frame zero, set a Force 1 depth keyframe of let’s say 3.00. Then at 5 sec, keyframe your force ball depth with a setting of zero. You’ve now got aball that moves from a depth of 3 to 0 over 5 seconds. Fun stuff.
I envy you your first time with AE. It’s really an amazing prgram and a lot of fun to learn. You’re gonna have lots of “Eureka!” momnets over the next few months. Good luck.Scott_Sepngler
John Cuevas
April 15, 2005 at 2:36 pmhttps://www.creativecow.net/show.php?forumid=1&page=/articles/unguren_ben/shatter/index.html
That’s everything you wanted to know about shatter but were afraid to ask.
Chris Ives
April 18, 2005 at 11:20 amScott,
Thanks for that, and as you said EUREKA! It works!!!! WOOHOOOOOOO!
Chris
