Activity Forums Blackmagic Design New Adobe Premiere Pro CS4 update to V4.1.0
  • New Adobe Premiere Pro CS4 update to V4.1.0
    Posted by Yasser Amin on June 22, 2009 at 9:25 pm
    Hello
    Is this the expected update from Adobe ?
    do we will see new Decklink Driver update to solve all the problems we get with Premiere CS4
    New in this release
    – Additional support for REDCODE.
    – Performance improvements to project load time. – Improvements to AVCHD support.
    – Performance enhancements for DV/HDV playback.
    – Support for Avid captured DV or IMX footage.
    – Export media to a still format now bypasses the AME render queue. – Enabled .VOB extension support.
    – Third-party support
    Notable fixes
    – All clips in last active sequence are no longer redbar when reopening project
    – Boris FX can get the clip dimensions for their filter setup dialog
    – CTRL+M is now the default shortcut for File‐>Export‐>Media
    – A bug that caused green frames in clips with 100% reverse speed applied has been fixed.
    – The last few frames of a time remapped clip are no longer rendered green
    – Adobe Premiere Pro can now open projects created in Adobe Premiere Elements 7
    – ’Scale to Framesize’ on a clip in a sequence of matching frame size and PAR no longer causes the timeline to require rendering.
    – A bug that caused corruption in exported TIFF files has been fixed.
    – Several issues with Adobe After Effects Filters and Track Mattes have been fixed.
    – Performance improvements have been made to Direct Manipulation
    – AVCHD 720p 30p are now imported correctly.
    – Relinking XDCAM EX clips that have been moved to a new directory is now more intuitive.
    – A bug that caused fields to be reversed when rendering speed change on upper field first footage has been fixed.
    – A user can now copy and paste R3D footage from Adobe After Effects to Adobe Premiere Pro
    – Several issues with effects that use track inputs, when the input track is a still have been fixed
    – Playback performance of ProRes clips has been improved.
    – Playback performance of h.264 clips has been improved.
    – XDCAM EX clips no longer play one only audio track in the Source panel
    – A playback issue with Panasonic AG‐HMC150 recorded progressive AVCHD clips no longer causes application freeze
    – Blackmagic can now display titler output on external monitor
    – If a mapped drive is defined as the user folder for a roaming profile, Adobe Premiere Pro no longer crashes when attempting to write to the drive.
    Known issues
    – Progressive 720 Sony AVCHD media files show an interlaced frame rate in Media Browser and Metadata panel.
    – AVCHD 1080p 30 and 25 progressive clips are interpreted as interlaced files in Adobe Premiere Pro CS4 projects.
    – If the work area end position is greater than the last frame of the last clip in sequence, then entire sequence is exported instead of work area.
    – Setting sequence-marks stops playback if the multi-camera monitor is open.
    – When importing QuickTime clips in AME’s batch queue for export, certain types of metadata (such as timecode) will not be propagated to newly generated clips.
    Yasser Amin replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
