Activity › Forums › Sony Cameras › New 900
New 900
Posted by Robin Probyn on January 2, 2006 at 12:48 pmHi there
What are the main,if any,differences between the the old and newer 900,s
And can someone tell me the best shutter angle to get rid of flicker from florescent lights in the US ie 60htz when shooting 25 FPS and 24 FPS and 23.97.
Any other helpful hints!
Robin Probyn replied 20 years, 8 months ago 4 Members · 14 Replies -
Paul Thurston
January 2, 2006 at 3:20 pmHi,
Where in Tokyo are you? Just curious…
Michael Bravin, Chief Technology Officer of Band Pro wrote some things about the camera in the HD Hi End forum. According to him, it “…is basically the same imaging and processing as the F900. It was necessitated by the international agreements to remove lead (primarily in the solder) from the manufacturing process. The F900 R will be built on the HDW 750/730 chassis so it will be a slight bit shorter and smaller. It will be a bit lighter also.”
Flicker from fluorescent tubes is a problem that has some very simple solutions. You can change the ballast of the tubes to an electronic ballast which turns the flicker to 20,000 Hz (flickerless for all practical purposes) or you can change the shutter speed of your camera. For video/HD it would be something like this:
In a 60Hz country (tubes flicker at 60Hz)
Shooting fps speed: 23.98
Shutter speed: 60Shooting fps speed: 24
Shutter speed: 60Shooting speed: 25
Shutter speed: 60Shooting speed: 29.97
Shutter speed: 60Shooting speed: 30
Shutter speed: 60Shooting speed: 60
Shutter speed: 60In a 50Hz country (tubes flicker at 50Hz)
Shutter speed: 50Shooting fps speed: 24
Shutter speed: 50Shooting speed: 25
Shutter speed: 50Shooting speed: 29.97
Shutter speed: 100Shooting speed: 30
Shutter speed: 100Shooting speed: 60
Shutter speed: 100Regards,
Paul Thurston -
Michael Brennan
January 2, 2006 at 5:29 pmIt looks like it will use a IT rather than FIT ccd so there is a (technical) difference. It could use 14bit AD rather than 12bit.
In theory it should be slightly better if they haven’t gone cheap and not ironed out any bugs.We’ll wait and see.
Summising now…
If they are using the block from the 1500 then with a big increase of ram the camera could do a minute of 1440×1080 60p before downloading to tape.
OK it ain’t gonna happen, they’ll do that on the SR camcorder first… then in say 2008 it will be available on HDCAM…Mike Brennan
Robin Probyn
January 2, 2006 at 11:53 pmHi
Iam right in central Tokyo,next to Tokyo bay.I was more wondering about shutter degree,s for shooting 24 and 25 fps with 60htz flouries.
Paul Thurston
January 3, 2006 at 1:59 amFor Film Cameras (and HD cameras too)
To get rid of flicker from fluorescent lights, mercury vapor lights, metal halide additive lights, high pressure sodium lights (street lights), CSI lights, CID lights, non electronic ballast HMI lights and similar AC arc discharge lights, the following shutter angles and speeds are required:
50Hz Country (fluorescent tubes flicker at 50Hz)
fps: 24
Shutter angle: 172.8 -
Robin Probyn
January 3, 2006 at 10:43 amHi Paul
Thanks alot for your time and help with this.Iam used to 50htz but wasnt so sure about 60htz.
Thanks again,happy new year
Robin Probyn
January 5, 2006 at 12:22 amHavnt started yet,I,ll fly to the US this sunday for 12 days.
So the F900 has only shutter settings as fraction of seconds eg 1/60th not degree,s like the varicam? not that it matters as long as it does the job
thanks
Morveren
January 12, 2006 at 9:50 pmHi
We will be shooting Tokyo in Feb. We are using Lowel Rifas as part of our kit – can we get hold of 100V lamps for these in Tokyo (100V VS 110V) as the standard lamps from the US are 110v so will burn warm…do you have a contact for a lighting supplier in Tokyo we could use? Also what’s the average cost for an f900 Weekly hire in Tokyo?
Cheers JAY -
Paul Thurston
January 13, 2006 at 2:57 amIn Western Japan, voltage is 100V 60Hz while Eastern Japan is 100v 50Hz.
https://www.equitech.com/support/worldpwr.html
I would send Lowel an e-mail and ask your questions directly to them.
https://www.lowel.com/contact.htmlIf that’s a bad idea, here is the Lowel Japanese distributor:
Honjo & Company
No.5,4-Chome Koyoucho-Higashi
Higashinada-ku Kobe 658-0031Phone 81 78 8572151
Fax 81 78 8572171Honjo & Company
1-7-9,Nishi-Azabu,Minato-Ku
Tokyo 106-0031Phone 81 3 5411 8841
Fax 81 3 5411 8861For a Tokyo HDCam rental facility (Sony HDCAM – HDW 750):
https://www.asiahiretokyo.com/Or try a search at mandy.com
https://www.mandy.com/place/japa.cfmRegards,
Paul Thurston -
Morveren
January 13, 2006 at 3:24 amThanks Paul – appreciate your local knowledge – are you based in Tokyo as a freelance cameraman?
Cheers JAY
