Activity › Forums › Apple Final Cut Pro Legacy › Never thought I’d be doing this again…It’s nearly 2012
  • Never thought I’d be doing this again…It’s nearly 2012
    Posted by Ben Oliver on December 22, 2011 at 3:54 pm
    I need to capture VHS.
    I have FCP7.
    I have a DSR11 Deck
    I have rca cables.
    I have a firewire deck.
    I can capture DVCAM tapes fine via firewire.
    The outputs on the VCR are fine and work.
    I can record the VHS to DVCAM fine.
    My FCP Settings are set to non-controllable device and DV NTSC 48k
    My scratch disc is a firewire 800 drive.
    I cannot seem to get the video to passthrough. all the parts are working, but not the whole…
    Thanks for your help!
    Ben Oliver replied 14 years, 9 months ago 3 Members · 5 Replies
  • Chris Babbitt
    December 22, 2011 at 4:05 pm
    Is the input on the deck set to”Line?”
  • Ben Oliver
    Yes…I got it to work….with QUICKTIME 7……
    -Ben
  • Ben Oliver
    December 22, 2011 at 4:10 pm
    Theres just like, 400 tapes here, and that will basically double the time. I think I will just capture right into the machine and make dvds where appropriate!
    But thanks for the advice!!!
    -ben
  • Mark Suszko
    December 22, 2011 at 5:16 pm
    With 400 tapes to capture, I think what I would do is buy a tunerless DVD recorder for less than a hundred bucks, dub the VHS over to DVD-R’s, then use the DVD’s as archive and edit source, converting them to work on my FCP-7 timeline with Squared-5’s mpeg streamclip free utility, or use (shivers) FCP-X. The DVD’s will import really fast, and you can be editing while the DVD recorder is capturing next door.
  • Ben Oliver
    December 22, 2011 at 9:57 pm
    Thanks for the advice!
