Activity › Forums › Creative Community Conversations › Never seen this before
Posted by Xavier Paredes on May 2, 2016 at 2:31 amCan someone please tell me what that thin bar above my main clip is? I have no idea what I did but it suddenly appeared. How do I make it go back to how it was originally?
https://dl.dropboxusercontent.com/u/3076447/Final_Cut_Pro.png
thanks!
Xavier
Nick Toth replied 10 years, 4 months ago 6 Members · 6 Replies -
Noah Kadner
May 2, 2016 at 4:01 amCan you be a little more specific? Are you talking about the clip labelled bells 2 edited. That looks like a connected clip in compact clip appearance setting https://support.apple.com/kb/PH12556
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops -
Bill Davis
May 2, 2016 at 4:25 amEither that or you accidentally double clicked the clip and expanded the audio and video components when you had the clip appearance set all the way to audio.
Try double clicking in the grey area between the upper and lower parts of the clip. If it collapses into a single entity – that’s what’s happening.
New signature under construction and coming soon. Please stand by…
John Rofrano
May 2, 2016 at 12:06 pm[Bill Davis] “Either that or you accidentally double clicked the clip and expanded the audio and video components when you had the clip appearance set all the way to audio.”
Yea, that’s what it looks like to me too. Right-click the clip and select Collapse Audio/Video Components and it should go back to normal. Note the keyboard shortcut for this is Control+S so simply pressing ^S by accident could cause this to occur without you knowing what has happened.
BTW, Questions like this belong on the Apple FCPX Techniques Forum.
It would be nice if the forum names made some logical sense. 😉
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Nick Toth
May 2, 2016 at 12:59 pmJust double-click on the audio track and it will collapse. You probably double-clicked on the clip when in waveform only view.
Mathieu Ghekiere
May 2, 2016 at 4:34 pmOr what is often a bit easier then double clicking on just the right height is the shortcut Control+S.
https://mathieughekiere.wordpress.com
Nick Toth
May 2, 2016 at 4:59 pm[Mathieu Ghekiere] “Or what is often a bit easier then double clicking on just the right height is the shortcut Control+S.”
Indeed!
