Activity Forums Apple Final Cut Pro Legacy neutral density fix
  • neutral density fix
    Posted by Judy Singh on March 21, 2006 at 5:14 pm
    I’m a moron and didn’t use my nd filter because sometimes it makes my footage too dark. well now my picture is too hot. does anyone know of a fix for this in FCP? I’ve fiddled with the gamma, brightness, contrast, white and black levels but nothing looks quite right.
    is there an nd filter you can add in post??
    thanks much.
    Judy Singh replied 20 years, 6 months ago 2 Members · 3 Replies
  • Bouncing Account needs new email address
    March 21, 2006 at 7:13 pm
    This is a very serious problem, as “over-iris” can be difficult to correct (it loses image data in the too-bright areas.)
    But, I saved this from last year on the COW:
    Date: Mar 26, 2005 at 11:09 pm
    Subject: Re: footage way 2 bright!
    Multiply mode is particularly effective – if there’s any detail in the highlights it will build up (Multiply mode always darkens an image). Don’t be afraid to stack more than 2 copies to get the density you might need.
    if you want to thicken up the highlights without darkening the darker areas, try isolating the highlights with a chroma key filter (yeh, don’t worry about the name) set to near white to pick out the highlights (you’ll need to invert the chroma keyer but that’s easy).
    Or you can add the Color Corrector 3-Way Filter and slide down the “White” and “Mid” level controls.
  • Judy Singh
    March 21, 2006 at 7:43 pm
    Thanks for saving this! I haven’t been able to find any info anywhere on how to deal with this problem.
    When it says to isolate the highlights with the chorma key, it means to then use the multiply filter after applying the chroma, right?
    I’ll give it a try and let you know how it works.
    thanks,
    j
  • Judy Singh
    March 22, 2006 at 5:34 pm
    the fix is nowhere near what i was hoping it would be. the blacks really get crushed. i tried making the opacity of the multiply layer to tone it down a bit but it still looks pretty wonky. guess there really is no substitue for doing it right the first time. thanks so much for your help.
    j
