Activity Forums DaVinci Resolve Neutral Background
  • Neutral Background
    Posted by Andrew Smith on August 22, 2011 at 8:28 pm
    Hello
    I included a picture of my first attempt at creating a neutral background over a glossy brick wall. I have a calibrated plasma which sits right in front unfortunately, but I used this setup recently for a client’s indie feature. I am thinking the botero collapse background unit in this picture looks way too wonky and that a larger paper background with stand might just make more sense and look more professional? I have 6500K lighting behind the plasma but not hung properly just yet like they do on ecinema’s website studio pics. I would be spending a few hundred it looks like but to set up and take down each time I have a client over might be a bit of a pain as well.
    I am also concerned about the reflection on the ceiling from the Fluorescent 6500K light…does that look problematic to you guys?
    I would love to also get advice on other lighting in the room to make it adjustable for non-film work (Web, TV, etc). Right now its dark enough for film work for sure but I wonder if its TOO dark in the room overall – possibly some more D65 lighting in a back corner of the room coming from the floor facing up towards the back wall?? Not sure how to make that look good in a client living room space on a budget, these fluorescent fixtures are not exactly nice floor lamps or designed to look good alone on the floor or a wall.
    I sit to the right of the plasma about 10 feet away also against that brick wall at a workstation with my own calibrated monitor and computer monitors for gui.
    Any help or pics would be great.
    thank you
    MacPro 4,1 OSX 10.6.8 / FCS3 / CS5
    2.26 ghz 8-core / 24GB RAM
    Nvidia GT 120/285 combo
    Andrew Smith replied 15 years ago 5 Members · 7 Replies
  • 7 Replies
  • Toby Tomkins
    August 22, 2011 at 10:35 pm
    Why not paint the wall grey? Get Dulux ‘6000N’ mixed at your local hardware store. That is 18% grey, the same as a grey card. Don’t use off the shelf grey paint as it usually has a little blue in it (from the white they use). Lighting levels depends on your monitoring (specifically the amount of light coming out of the monitor). There’s calculations out there for conversions. 18% grey lit ‘dimly’ with 6500K light works for most scenarios in my experience. Dimmable 6500K LED’s would be nice.
    Good luck.
  • Omar Godinez
    August 23, 2011 at 12:46 am
    Maybe you can paint your wall with Sherwin Williams SW7071 grey paint. https://www.sherwin-williams.com/do_it_yourself/paint_colors/ideas/color/SW7071/. It’s very close to 18% grey.
    Also, consider purchasing the CinemaQuest Ideal-Lume Pro for wall illumination. https://www.cinemaquestinc.com/ideal_lumesb.htm
    Omar Godinez
    Dallas, Tx.
    Resolve Suite:
    MacPro5,1 2.93GHz 12-Cores
    12GB RAM
    ATI Radeon HD-5770 1GB
    Film Systems 5-Slot 80Gbps Expansion Chassis w/2 Modified GTX-470s & 16TB RAID5 Storage
    FSI LM-2461W
    BMD Ultrascopes
    Tangent Devices Wave Panel
    50″ Panasonic 12 Series Pro Plasma HD-SDI
    Cinemaquest Ideal-Lume Pro
    Sherwin-Williams SW7071 18% Grey
    APC Back-UPS
  • Andrew Smith
    August 23, 2011 at 1:24 am
    Well my whole point is that I CANNOT paint this beautiful brick wall grey at all which is why I have tried these other methods…
  • Ben Starkey
    August 23, 2011 at 1:50 am
    I think I’d consider purchasing a piece of drywall or fiberglass the size you want for back surround, mounting it to the brick wall, and then painting that to neutral grey.
    Ben Starkey
    Colorist
  • Andrew Smith
    August 23, 2011 at 2:47 am
    hmm trying to imagine that and how I could quickly put it up for client sessions and otherwise put away easily for when its just a living room for normal tv / film viewing etc.
    thank you for the replies thus far, much appreciated!
  • Paul Provost
    August 23, 2011 at 4:41 am
    4′ x 6′ foam core from art supply store
    2 or 3 of them should do it
    very light and cheap – easy to hang
    non reflective surface – available in a close enough grey for your needs
    https://www.postandbeam.tv
    grade and finish @ post + beam
    https://www.facebook.com/pages/post-beam/137967176232067
  • Andrew Smith
    August 23, 2011 at 5:33 pm
    Hey Paul not a bad idea. Would I then just paint it 18% gray, also thinking about how to mount in a way that would allow for it to look clean t and unmount when not grading??
    I will try to go to have a look today at an art supply store for a solution.
    thank you
