Activity Forums Apple OS X Networking issue
  • Networking issue
    Posted by David Roth weiss on June 21, 2009 at 5:18 pm
    I’ve run two runs of cat-6 cable in my home, each about 100ft, and it seems that neither my cable modem nor my router are sending a signal strong enough to establish an internet connection on either of the two computers 100ft down the line. In other words, whether I go direct from the cable modem to one of the computers, or go from the router to one or both computers, the I am getting a green ethernet light, but still no internet connection.
    BTW, as a test I found it will work just fine with a 50ft cable, but that doesn’t really help me in this situation. My understanding is that cat-6 cable should be able to handle a run of 300ft on a network, so it seems like 100ft should be a no-brainer. Does anyone have any suggestions?
    TIA,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
    J. Tad newberry replied 17 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Dan Asselin
    June 21, 2009 at 6:02 pm
    Iknow this may not be at all what you are looking for but have you considered something like this.
    https://www.amazon.com/DIGITAL-AMPLIFIER-INTERNET-SIGNAL-BOOSTER/dp/B000F291V2
    David: my boss and I do boardroom installations and the first thing we check when we have problems like this is the connections to see if they are tight.
    Good luck….wish I had some better ideas
    Dan
  • David Roth weiss
    June 21, 2009 at 6:21 pm
    Thanks Dan, that could be the answer and one I might try. However, I just read a tech support thing on the Internet that said that there should be no difference between a 5ft run and a 300ft run of cat-6 if the connectors are installed properly, so I’m wondering about those now. A friend showed me how to put the connectors on, and I’m wondering if we screwed them up somehow. We used “EZ” connectors, designed to make the connections foolproof, but I’m still suspecting something might be wrong.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Dan Asselin
    June 21, 2009 at 6:44 pm
    I think you are right. We have done connectors before and it is really easy to mess up. Good Luck
  • J. Tad newberry
    June 23, 2009 at 11:19 pm
    Hmmm…and i’ve just networked my Mac Pro, G5, a XP PC, and my daughter’s wireless laptop. My two Macs and the PC can all read and print from the printer that is USB’ed into the G5, and my daughter’s laptop can SEE the printer, but it won’t print. ???
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Mac Pro 2.66 GHz Quad-Core
    3 GB RAM
    http://www.bigya.tv
  • Jake Taylor
    June 25, 2009 at 12:18 am
    David,
    My suggestion is to check the wires themselves. Wires could be crossed or bad connectors. It just wouldn’t make sense that the 50ft ones work fine.
    Best of luck,
    Jake Taylor
    Jake Taylor
    Consultant / Systems Engineer/Apple Technician – Video, Final Cut Pro
    Apple Consultants Network – Storage Area Networks
    SANtech.TV
    17518 Von Karman Ave.
    Irvine, CA. 92614
    Office: 714-639-3767
    Fax: 714-783-7820
    jaketaylor@santech.tv
    https://www.SANtech.tv
  • Bob Cole
    August 13, 2009 at 10:03 pm
    ever fix it? There’s a story in the NY Times today about home networking.
    Bob C
  • J. Tad newberry
    August 15, 2009 at 10:40 pm
    Half way. I got my Windows XP to be able to print on the printer that is connected to my Mac G5, but my Mac Pro still won’t print…i’ll dig around for the NY Times article. Thanks for asking.
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    3 GB RAM
    http://www.bigya.tv
