Activity › Forums › DaVinci Resolve › networking for more processing power.
Posted by Chris Larsen on January 26, 2013 at 7:57 pmI recently purchased a mbp that has a quad core processor. I also have a late 2009 27″ imac with a quad-core i7. Is there any way that I can connect the 2 and use the display of the imac while utilizing the processor to help with exports, renders, and other things? 2009 iMac doesn’t have thuderbolt, but if I get an ethernet adapter, is there a software solution for utilizing the idle processors?
Chris Ramey replied 13 years, 6 months ago 7 Members · 8 Replies -
Margus Voll
January 27, 2013 at 12:06 amResolve is gpu based and as far as i know you can not combine machines if you are not on linux version.
So i’d say no.
Margus
https://iconstudios.eu
https://vimeo.com/iconstudioseu/videosDaVinci 9, OSX 10.7.4
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro -
Dan Moran
January 27, 2013 at 6:48 pmI think its a Linux only feature also. It uses Infiniband instead of ethernet too.
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog -
Juan Salvo
January 27, 2013 at 7:56 pmYeah 40Gbps infiniband at that. Far, far cry from 1gigE
Colorist | Online Editor | Post Super | VFX Artist | BD Author
Chris Larsen
January 28, 2013 at 8:51 amThank you all for your input. Any suggestions for what I should do with my imac? Sell it, turn it into a part time monitor, any other ways to utilize the processor when it’s in monitor mode for other post functions? The graphics card can’t handle resolve on its own. Maybe I cut on the iMac and finish on the Mbp?
Margus Voll
January 28, 2013 at 8:53 amOr look at the latest iMacs as Peter posted some times ago here.
Margus
Multibridge 2 Pro -
Eric Sternberger
January 28, 2013 at 9:15 aminteresting Idea though….
would it work with two iMacs connected via thunderbolt?? -
Joseph Owens
January 28, 2013 at 5:05 pm[Eric Sternberger] “would it work with two iMacs connected via thunderbolt??”
No… see above…
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Chris Ramey
February 24, 2013 at 4:23 amThere’s a few apps that would let you use your second laptop as a second monitor. Air Display is one of them. It’s similar to screen sharing, you might get a performance decrease since computer #1 will be serving a video stream to your second computer.
