Activity Forums Storage & Archiving Network Wiring for MacPro SmallTree Network
  • Network Wiring for MacPro SmallTree Network
    Posted by Dylan Harrelson on June 16, 2014 at 6:28 am
    Currently working as a networking consultant that has a MacPro managing a expandable SAS-connected array as well as a SmallTree Gigabit 6-Port card that is connected directly to 6 machines via Cat6. Recently added two more machines and issues have started to appear. As a temporary fix I have the ethernet ports connecting these two additional machines to the network.
    Quick specs:
    Mac Pro 2.66 GHz Quad-Xeon (Single)
    16 GB RAM (Max)
    10.9.3 Mavericks
    Machines are now experiencing random disconnects to the server and the array. I have updated firmware on all cards and performed the OSX driver fix for the SmallTree card. The network addressing was configured as such:
    Server-end (Manual addressing)
    10.0.0.1x | Subnet: 255.255.0.0
    Machine-end (Manual addressing)
    10.0.0.2x | Subnet: 255.255.0.0
    Current resolve to the problem is a full disconnect/reboot on both sides but I seem to experience issues after 4+ machines start connecting to the array.
    Trying to plan for future-proofing as well. I need to expand the number of machines able to connect to the array. I assume I will need a 10Gbe card in the MacPro running to 10Gbe switch that will distribute Cat6 to each of the machines. Any further recommendations on this matter would be greatly appreciated.
    Dylan Harrelson
    Digital Media Professional
    Scott Goddard replied 12 years, 2 months ago 5 Members · 4 Replies
  • Tim Ward
    June 16, 2014 at 2:19 pm
    Dylan, give us a call. We’ll help you out.
    1-866-782-4622 Option 1
    Tim Ward
    Small Tree Communications
    tim@small-tree.com
    http://www.small-tree.com
  • Ed Stahr
    June 19, 2014 at 4:36 pm
    How did you add two more machines? Did you have four and now you have six or did you connect to another ethernet port for a total of eight clients?
  • Steve Modica
    June 20, 2014 at 10:28 pm
    Hi Dylan
    I imagine you got this answer already, but I think Apples old 82546 driver (PCIX) is jumping in and grabbing our card. It seems to grab our intel chipset because the vendor ID matches (8086 is the Intel vendor ID. That’s really funny if you’re old enough to remember the first Intel cpus 🙂
    Anyhow, we have a KB entry on this problem here with a solution:
    https://www.small-tree.com/kb_results.asp?ID=44
    Steve
    Steve Modica
    CTO, Small Tree Communications
  • Scott Goddard
    July 3, 2014 at 10:28 am
    Hi Dylan,
    I am looking to put together a very similar setup. Other than this driver issue, how do you find the performance for the client machines?
    Scott Goddard
    Neo Verite Limited
    https://neoverite.com
