Activity › Forums › Adobe After Effects › Network Rendering?
Network Rendering?
Posted by Jake Sedge on September 22, 2009 at 6:28 pmHi,
I have a fairly good computer, but I can’t output 1080p HD without lag. I am building a similar computer for my friend. I have heard about network rendering, my question is, would I be able to use this, how would I set it up and how effective would it be?The main problem is that my friend lives about a mile away so we cannot share a wireless network. How would we create a network? I do have an old computer I could use as a server if necessary.
Jake Sedge replied 16 years, 11 months ago 3 Members · 7 Replies -
Jake Sedge
September 22, 2009 at 7:09 pmSuppose your right! The problem I have is after the export where the video stops and starts and the sound is distorted. This is not a playback problem. In Premiere Pro, I used to get perfect playback, so it must be a problem I have with AE rendering.
I am not trying to speed up render times or playback,I just want the output to be good.
Oh, and sorry, it’s 1080i, and it IS HDV.
David Bogie
September 22, 2009 at 7:18 pmWhat’s that distributed engine called, Nitro, Atomic Waste, Embolism, something like that.? It’s highly regarded.
bogiesan
Jake Sedge
September 22, 2009 at 8:16 pmThanks SO much! The video I am working with is m2ts from a Sony AVCHD camcorder!
Which format would you convert it to, and what program would you use, because all the converters I have used produced sub-standard quality and was often choppy itself.
Jake Sedge
September 22, 2009 at 10:09 pmThanks so much for your input! I will be experimenting with a few different pieces of software in the morning (its 11PM here in the UK!). I can’t thank you enough for your help!
Stuart Elith
September 23, 2009 at 4:07 amJake, in addition to the comments from Dave, I have to question what you mean by “after the export where the video stops and starts and the sound is distorted. This is not a playback problem.”
Are you saying that AFTER you export a project from After Effects, when you go to look at it in a media player (such as quicktime) the playback skips and lags? Because this is a separate problem, not to do with after effects. Computers have to decode videos for playback, and this takes differing amounts of processor power. So on my 8-core mac, I can’t play uncompressed HD footage in realtime (in Quicktime) but if I convert it to a different codec such as H2.64 I can…
But this may not be what you mean, it’s just what I interpreted 🙂
Jake Sedge
September 23, 2009 at 12:46 pmSo, am I looking for a M2TS compressor or converter, and which codec would you recommend? I am not very good with codecs, so are there any standard codecs you could suggest?
Jake -
Jake Sedge
September 23, 2009 at 3:10 pmGREAT NEWS FOR ANYONE WITH THE SAME PROBLEM AS ME!
To tackle the problem of choppy output:
1)I imported the M2TS file into Sony Vegas.
2) Cropped it and rendered as WMV V11 with a 5Mbps HD 720-25p template (my hard drive is not up to 1080!)
3) Imported into after effects and did what I needed to do with it (preview was smooth)
4)Rendered as Windows Media 1280×720
5) After my hard drive got used to it, it played back very smoothly, with a fair quality loss, but nothing major, and no annoying horizontal lines like when you convert it using a normal converter.
Thanks to Dave LaRonde for getting me this far!
