Activity Forums VEGAS Pro network rendering Question???
  • network rendering Question???
    Posted by Wade Harrington on April 9, 2005 at 10:43 pm
    I am trying to run two instances of the network renderer. I have a HT chip and want to render things faster. I have tried the following according to the help file. One instance works fine. WhenI type in the command line to start the second I get the following message
    “an error has occured configuration file does not exist. the app. must quit.
    Below are the command lines i’m using
    At command prompt:
    cd c:program filessonyvegas 5.0
    vegSrv50.exe -nosave -config NetRenderClient.config (default port)
    vegSrv50.exe -nosave -config NetRenderClient2.config (add 1 number up from default)
    Wade Harrington replied 21 years, 5 months ago 3 Members · 5 Replies
  • Donatello
    April 10, 2005 at 9:44 pm
    i’m pretty sure you need dual cpu to run 2 NRS ( renderers at same time ) on one computer..
    i believe to run 2 NRS (one computer) you need to assign the 2nd NRS to run the 2nd CPU on a different TCP port. default might be 53704 so the 2nd TCP needs to be different
  • Gary Kleiner
    April 11, 2005 at 12:23 am
    [donatello] “i’m pretty sure you need dual cpu to run 2 NRS”
    No, you can run two network nodes on a hyperthreaded machine.
    As you suggest, you need to set up an alternate port.
    Gary Kleiner
    Vegas Training and Tools.com
  • Wade Harrington
    April 11, 2005 at 12:40 am
    Thats what I did, and it doesent work. See my original post.
  • Donatello
    April 11, 2005 at 7:36 am
    ?? recheck the net render service2 notepad to make sure it has all the . ” .rem <> = etc port=53705 all in right places ???
    make sure you have the back slashes
    At the command prompt, type cd “c:program filesSonyVegas 5.0”
  • Wade Harrington
    April 13, 2005 at 3:56 am
    Checked everything and it’s identical, I renamed the file to NetRenderService2.config and changed the port from port=”53704″ to port=”53705″ Still no go.
