Activity Forums VEGAS Pro network rendering question for vegas 5d
  • network rendering question for vegas 5d
    Posted by Anthony on July 28, 2005 at 12:07 am
    Im using a dual core cpu amd 4200 , so I want to use net work rendering on the one computer to use both cpus. I did the dos thing to create two ports. Then tired to follow the instructions for finding the computer name on xp right clicking on my computer doesnt give it to you. So I found it in system in control panel, I got the name its like tony-45687. Whats the proper way to put it in the network rendering under host. I tried putting in just tony-45687 and that doesnt work thanks. Also you can only network render avi’s correct?
    Anthony replied 21 years, 1 month ago 2 Members · 4 Replies
  • Gary Kleiner
    July 28, 2005 at 4:10 am
    Under the Renderers Tab, change the view to advanced. Just cut and paste the long-form entry and change the port number.
  • Anthony
    July 28, 2005 at 4:18 am
    What is the long form I put in ? I see other posts where I see a TCP// in front of the id ,do I have to do that . Pretend Im five and slow lol
  • Gary Kleiner
    July 28, 2005 at 4:52 am
    tcp://tony-45687:53705/NetRenderService.rem
    Gary
  • Anthony
    July 28, 2005 at 5:10 am
    Thank you Gary:)
