Activity Forums VEGAS Pro Network render question: Vegas 7 and Vegas 6
  • Network render question: Vegas 7 and Vegas 6
    Posted by Seatlanta on November 28, 2006 at 9:26 pm
    My main computer is running Vegas 7 with the included Network Rendering Service. I have two other computers, each with Vegas 6 and its included Network Rendering Service.
    Are the two network rendering modules the same? Can I use the Vegas 6 rendering module with the Vegas 7 rendering module?
    So far, I can see all the computers from the other computers, but network rendering still hasn’t happened. I’ve read just about everything I can find, and I’m wondering if these two versions may be causing the problem.
    Thanks.
    James (seatlanta)
    Don Donatello replied 19 years, 9 months ago 3 Members · 3 Replies
  • Edward Troxel
    November 28, 2006 at 9:32 pm
    Why not just load Vegas 7 onto the other two machines? Besides, Vegas 6 won’t load a Vegas 7 project file so I don’t think you’ll ever see that working.
    Edward Troxel
    JETDV Scripts
  • Seatlanta
    November 29, 2006 at 12:17 am
    Hi Ed:
    I’ve now loaded Vegas 7 on one of the rendering computers, and the render still fails. I’m just trying to let the second computer do the rendering–not trying distributed rendering at the moment (one thing at at time).
    The DNS suffix is the same for all computers. All computers “see” the other computers. The drives on both computers are all shared on my network. I selected “auto-fill mappings.”
    In the log, I get this error: The requested address is not valid in its context
    James (seatlanta)
  • Don Donatello
    November 29, 2006 at 11:22 pm
    using windows explorer check to make sure from each computer that you can go to the shared hard drive and transfer files back and forth ( between computer)
    are you using a router or do you assign each computer a IP address ( ie: 198.100.168.001)
    make sure each computer has different IP address …
    RUN – type in cmd .. then type ipconfig
