Activity Forums Adobe After Effects Network render consistencies
  • Network render consistencies
    Posted by Paul Roper on December 17, 2012 at 4:46 pm
    Hello,
    I have access to a network of Macs & PCs with varying levels of graphics abilities. Am I right in assuming that a “watch folder” multi-frame render would be OK (ie. all frames would have the exact same look) even if it were rendered with some machines using GPU acceleration and some not? Might there be some differences in the way a graphics card calculates, for example, motion blur versus a CPU’s idea of motion blur?
    I’m 99% certain the answer is “yes, it’d be fine, GPU or no GPU acceleration”.
    Paul
    Paul Roper replied 13 years, 9 months ago 4 Members · 5 Replies
  • Tudor “ted” jelescu
    December 17, 2012 at 8:52 pm
    My experience- yes there will be a difference.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Todd Kopriva
    December 17, 2012 at 9:14 pm
    If you’re seeing any such differences in After Effects CS6, please tell us. That’s a bug.
    Such differences were one of the major reasons that we threw the OpeenGL renderer in After Effects CS5.5 and earlier into the trash.
    After Effects team blog
    December 17, 2012 at 9:52 pm
    That was CS 5.5 and before- true.
    Todd- thanks to the AE team for the new audio options in the Render settings, you guys do listen! ;D
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    December 20, 2012 at 5:41 am
    [Paul Roper] “I have access to a network of Macs & PCs with varying levels of graphics abilities. Am I right in assuming that a “watch folder” multi-frame render would be OK (ie. all frames would have the exact same look) even if it were rendered with some machines using GPU acceleration and some not? Might there be some differences in the way a graphics card calculates, for example, motion blur versus a CPU’s idea of motion blur?”
    The answer is, as always, it depends.
    Some effects (like Magic Bullet Looks, Video Copilot Optical Flares and Element, and Mettle ShapeShifter AE and FreeForm AE) use OpenGL GPU acceleration, independently of the After Effects renderer. These are processing graphically on the GPU, and thus may be inconsistent from GPU to GPU.
    If you’re talking about the new ray-tracing renderer in CS6, or CUDA-enabled effects like GenArts Sapphire, then the GPU is not processing graphically; it’s processing numerically. The results should be identical in all cases to the CPU renderer.
    Walter Soyka
  • Paul Roper
    December 20, 2012 at 2:44 pm
    Thanks for that Walter. I suspected that AE did indeed just use the GPU for number crunching. For any work I do which requires non-standard plugins, I don’t do network renders due to the whole plugin licensing/installing thing, so that shouldn’t be an issue.
    – Paul
