Activity › Forums › Apple OS X › Network question
Network question
Posted by Alan Lacey on October 27, 2006 at 6:23 pmIt is possible to make a direct firewire connection between a single Mac and PC and make a direct peer to peer connection – anyone?
Alan
Alan Lacey replied 19 years, 10 months ago 2 Members · 4 Replies -
Bob Woodhead
October 28, 2006 at 5:50 pmYup, I use it sometimes. Must be on XP on the PC side. You’ll want a bit of shareware called SharePoints as well to make life easier. The protocol on the Mac side is called SMB. I did alot of searching/testing on this a couple of years ago, but forget where I posted the success results. Try searching the Apple forums. You’ll need to set a different subnet/IP range for the 1394 ports you’re using (than your ethernet). After all is set up correctly, you may need to wait a few minutes for the devices to “discover” each other as well. If I remember anything else helpful, I’ll post.
Alan Lacey
October 28, 2006 at 9:23 pmBob!!
Your a hero. Now I know it’s possible I’ll bust a gut to get it working.
If you remember any more details please post.
Thank you
Alan
Bob Woodhead
October 29, 2006 at 1:43 amI do remember that it was a real hassle without Sharepoints. Searching Sharepoints & SMB should find you the answers.
