Activity Forums Maxon Cinema 4D Network proxy settings for Cinema 4D
  • Network proxy settings for Cinema 4D
    Posted by Thomas Hannen on August 8, 2014 at 2:33 pm
    I’m trying to use the DEM Earth plugin for Cinema 4D R15 in OS X Mavericks, but I’m behind a corporate firewall.
    When I use a direct internet connection the software works correctly. When I’m on the corporate network, the DEM Earth object doesn’t appear.
    Has anyone else experienced this, with any other network-connected plugins?
    I’ve filled out the same HTTP proxy settings as my system uses in C4D’s Communications Preference pane, using port 80. Also tried the https proxy using port 443, but still no luck.
    I should say the plugin developer has also been trying to help, but I just wondered whether anyone here might have also experienced something similar.
    Many thanks in advance…
    Tom
    Thomas Hannen replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
