Activity Forums Apple Final Cut Pro Legacy network problem after upgrade
  • network problem after upgrade
    Posted by Joe on May 24, 2005 at 9:22 pm
    This may not be related but just after my FCP 5 upgrade finished I got the following message:
    192.168.1.108 in use by 00:01:03:33:f0:0e, DHCP server 192.168.1.1 Are there any network gurus who can help me resolve this? I have lost my connection to the internet.
    Shawn Bockoven replied 21 years, 4 months ago 2 Members · 1 Reply
  • Shawn Bockoven
    May 24, 2005 at 11:19 pm
    Someone else on your network is using your IP address.
    Hardware address is a unique identifier of a network interface card (NIC, a.k.a. Ethernet card), the piece of electronics in a computer that the network cable is plugged into, usually using a jack on the back of the computer. This is built into most Macs, laptops and pinters. In many PCs, some Macs and laptops the NIC is an add-on card. The hardware address is used to identify the machine on the network so an IP address can be assigned to it by a server. Therefore, it is required for all IP requests.
    FYI: hardware address is also called a MAC number which is not to be confused with a Mac
