  • Posted by Melissa on September 26, 2005 at 8:57 pm
    I know that managing media over a network is far from ideal. But, say you had to playback some QuickTime files in FCP HD over a Ethernet network. Are there any settings in terms of memory allocation, or system settings, that could make playback smoother?
    We’re using a Powerbook G4
    processor: 667 MHZ
    memory: 1 GB
    bus speed: 133 MHZ
    Mark Raudonis replied 20 years, 12 months ago 3 Members · 3 Replies
  • Robb Albrecht
    September 26, 2005 at 10:54 pm
    I think the only way you’ll see smoother playback is to have gigabit ethernet. You’re really up against the limitations of your network connection.
    Robb, Supervising Editor
    Aspect Studios
    http://www.lessthan3movie.com
  • Melissa
    September 26, 2005 at 11:31 pm
    We are doing this with an eMac also and that computer seems to do fine. It’s bus speed is a bit higher though..
  • Mark Raudonis
    September 27, 2005 at 2:51 am
    Melissa,
    We’ve got our whole company set up to look at quicktime files (off of the X-SAN) on their desktop via gigabit ethernet. This will work on both MAC and PC. Here’s some things to keep in mind.
    We’re using off-line RT, so our bandwidth needs are low. We have gigabit switches, cat6 wire, and enough spindles in our X-RAID’s to make it work. We can support up to around 20 seats in our set up. Probably could go higher, but just don’t have the need today. The higher your resolution, the greater your bandwidth needs. In other words, a couple of streams of DV quality might work. One stream of SD quality probably will NOT work.
    Doing this properly, you’re sticking your toes deep into “IT” land. If you’re comfortable there, go ahead. If not, hire someone who is.
    Mark
