Activity › Forums › Compression Techniques › NetStream.Play.StreamNotFound while trying to get RMTP snapshot
  • NetStream.Play.StreamNotFound while trying to get RMTP snapshot
    Posted by Gabriel Barreras on July 17, 2014 at 10:28 am
    I’m using the following command:
    ffmpeg -i rtmp://antena3fms35livefs.fplive.net/antena3fms35live-live/stream-antena3_1 -f image2 -vf fps=fps=1 out%d.png
    extracted from official FFmpeg wiki here.
    I am allowed to see the video stream using VLC with the same link. However, when using the command above, I’m getting this output:
    ffmpeg version N-64667-gd595361 Copyright (c) 2000-2014 the FFmpeg developers
    built on Jul 14 2014 22:09:48 with gcc 4.8.3 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzl
    libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amr
    enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --ena
    libavutil 52. 92.100 / 52. 92.100
    libavcodec 55. 69.100 / 55. 69.100
    libavformat 55. 47.100 / 55. 47.100
    libavdevice 55. 13.102 / 55. 13.102
    libavfilter 4. 10.100 / 4. 10.100
    libswscale 2. 6.100 / 2. 6.100
    libswresample 0. 19.100 / 0. 19.100
    libpostproc 52. 3.100 / 52. 3.100
    HandShake: client signature does not match!
    Closing connection: NetStream.Play.StreamNotFound
    rtmp://antena3fms35livefs.fplive.net/antena3fms35live-live/stream-antena3_1: Unknown error occurred
    What is the problem here?
    I’ve tried with other different rtmp streams and I’m still getting the same error.
    Thank you!
    Jim Sustacek replied 12 years, 2 months ago 2 Members · 1 Reply
