Activity Forums DaVinci Resolve Netstor pci expander with hackintosh. Candle Test
  • Netstor pci expander with hackintosh. Candle Test
    Posted by Jose Lomeña on August 26, 2011 at 4:28 pm
    Netstor NA250A
    – PCI expander with 4 pcie x8 + 2 pcie x4 slots
    – 40gbps host pcie x8 v2.  2 meters cable
    – up to 4x gtx480
    – setup with:
    2x gtx480
    1x. Decklink multibridge
    1x sonnet e4p
    2x free slots (for redrocket)
    My hackintosh…gigabyte  i7 980x, 24gb with:
    1x ati 5770 for monitors
    1x host Na250a
    1x gtx480
    Candle Test resuls with resolve8 and 3 gpu gtx480
    V1 2 nodes : 24 fps
    V2 4 nodes : 24 fps
    V3 6 nodes : 24 fps
    V4 12 nodes :24 fps
    V4-x2 24 nodes: 21fps
    V5 NR 4 : 24 fps
    V6 NR 3 : 24 fps
    V7 NR 2: 24 fps
    V8 NR 1 : 12 fps
    About netstor na250a
    Very good termination, interchangeable fans with variale speed selector. Fan  alarm, temp alarm. Aluminum. Very good power supply. The best price of the market.
    Is possible more gtx480?
    – I have 5 gtx480, i can run 4 + ati without decklink card, with 5 osx has a kp at the start. Only 3 + ati with decklink multibridge.
    Next step, my macpro… Any help with macpro 12cores + gtx480?
    Jose Lomeña.
    Sascha Haber replied 15 years ago 3 Members · 7 Replies
  • 7 Replies
  • Peszteres László
    August 26, 2011 at 5:29 pm
    Hi, Exelent!!! a little help I need, what would be a good setting for my system: ASUS P6T7 SUPERCOMUPUTER with Netstor +4 GTX-470, +Redrocket-card, +Highpoint-raid controller, Blackmagic-card,
    Thanx
  • Jose Lomeña
    August 26, 2011 at 7:59 pm
    Luigi at reduser is an expert of asus p6t7, he can help you with the config.
    The netstor is easy to config because you dont need to install drivers.
  • Peszteres László
    August 26, 2011 at 8:57 pm
    I asking about good slot-card (rules) configuration with a Netstor, because my Asus-Mac-supercomputer working very well,
    regards
  • Jose Lomeña
    August 26, 2011 at 9:47 pm
    Do you use p6t7 drivers from luigi?, or your own method?.
  • Peszteres László
    August 27, 2011 at 6:47 am
    Yes, I have.
    My Mac-Davinci system is like this: https://reduser.net/forum/showthread.php?54430-DAVINCI-RESOLVE-and-***HACKINTOSH***
    regards
  • Jose Lomeña
    August 27, 2011 at 7:33 am
    I think you can’t use netstor for gpu with your drivers, but better to ask luigi.
    Regards.
  • Sascha Haber
    August 27, 2011 at 10:53 am
    Yep, I will work on something like this for the next three month and grade around 10.000 shots .
    I really hope its as stable as it´s fast 🙂
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
