Activity › Forums › Storage & Archiving › Netstor na381tb raid enclosure – update
  • Netstor na381tb raid enclosure – update
    Posted by Robert P. dennis on April 23, 2014 at 7:48 pm
    Following my previous posts, I received my new 2013 Mac Pro, switched from my Mac mini using the thunderbolt cable, and the na381tb raid worked/works perfectly with the Mac Pro.
    I then received a new thunderbolt 2 card from Netstor and easily inserted it into the na381tb enclosure, in which I now have 2 internal and one external raid working seamlessly.
    The new setup is incredibly fast and reliable. I have gotten speeds of up to 1.1 GB/s, which is more than adequate for my needs.
    Comment: the speeds obtained vary with the type of file (particularly windows files). To obtain the best speeds, the powers that be will need to initiate a new standard for SATA ( Sata 4 ? ) hard drives????
    Haris Katsigiannis replied 11 years, 2 months ago 4 Members · 5 Replies
  • Bob Zelin
    April 23, 2014 at 10:51 pm
    Hi Robert –
    1.1 GB/sec is 1126 MB/sec. We too have seen between 1100 – 1200 MB/sec with the Netstor chassis, and are very happy with this product. HOWEVER, even with SATA 4 drives, you are not going to get a Thunderbolt 2 product to do more than 1375 MB/sec – Only Intel controls this power !
    Following Lacie’s trick at the NAB show, we too took two TBolt 2 chassis (8 bay) and striped them together (both RAID 0 which we would normally NEVER do, but I wanted to push what I could get for results), and used Apple Disk Utility to RAID 0 these two Tbolt 2 arrays, and we got 2000 MB/sec. Now, this is unrealistic, and I would NEVER sell a configuration like this, because of potential data loss, but it did work, and we did “fake out” the Thunderbolt 2 speed limit. So what does this mean – ABSOLUTELY NOTHING, but it was a fun trick.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Simon Blackledge
    May 23, 2014 at 12:14 pm
    What were you getting from the Mac mini ?
  • Robert P. dennis
    May 23, 2014 at 4:32 pm
    Hi simon-
    Up to 750 MG/s which is the limit for sata3.
    Bob
  • Simon Blackledge
    May 23, 2014 at 9:43 pm
    Sata3 ? Seems at 750MBs you saturated the thunderbolt 1 port no?
    Not sure what sata3 has to do with it ?
    Still think TB2 will be the bottleneck if you filled the 24bays with ultrastars and connected them to a 6 (now 12) GB Areca raid card.
    Nice setup though. I do like the netstors we have.
  • Haris Katsigiannis
    July 12, 2015 at 11:02 am
    Hello bob,
    what do you think it would be the best configuration for the NA381TB, to run faster (read/write) ?
    Have any ideas since you have installed some of these?
