Activity › Forums › Maxon Cinema 4D › net render probs – need help
  • net render probs – need help
    Posted by Jonas Espinoza on January 28, 2007 at 1:50 am
    i have my net render set up, the clients/server see each other. the job is uploaded, but in my results folder im getting tons of little tiny tiff files. am doing a 2k tiff sequence, which should be 1.3 meg tiff’s
    i have the path set to a certain place in the projects output, doesnt seem to want to go there when i search for tiff’s
    this is my first try with this, but could really use the extra speed.
    i alsoo saved the proj with the tex folder. any insight would be great
    Björn Marl replied 19 years, 8 months ago 2 Members · 1 Reply
  • Björn Marl
    January 28, 2007 at 8:57 am
    the render path you have choosen in your project file is ignored by net renderer. It will always save the result files in
    the CINEMA 4D Net Server installation directory /User/[Username]/[Projectname]/Results
    The small images you found might be the temporary thumbnails created to show the progress.
    Cheers
    Bj
