Activity Forums Maxon Cinema 4D Net Render Problems
  • Net Render Problems
    Posted by Jobert Monteras on July 29, 2008 at 3:30 pm
    I’ve got 4 computers and I’m trying to use net render I tried it first with simple scene and had a jpeg sequence output it work fine but now I am using a scene with 3 cloner objects, each cloner is consist of 4 objects namely a ball, lips, star, notes then on each cloner I rearrange the order of the objects so that it would look random. Then each has a step effector so that the objects would appear at a time. The problem is when I use net render it only renders the same frame but with increments for example it would render only frame number 1 and if I have a hundred frames to render I would also have 100 hundred frame number 1 it’s as if I had a frame hold effect applied in it and the other problem is inside the frame there is only one object in my case the lips is only rendered and the cloner is not applied. I checked all my settings and it is correct because I set them to render all frames then targa output. Can somebody help me here please.
    We are actually using Maya in the office but I’m pitching to my boss to shift our softwares to Cinema 4d because I find it easier to use and also give’s great result but if I can’t get to make Net Render work properly then we might go back on using Maya 🙁
    Jobert Monteras replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
