Activity › Forums › Maxon Cinema 4D › NET render problem/limitation?
  • NET render problem/limitation?
    Posted by Kevin Cook on December 20, 2010 at 8:57 pm
    I have an abnormally large scene file (depending on how it’s set up between 2 and 3 gigs), the bulk of the scene file size coming from render instances.
    I tried rendering the scene file via Net Render and I got an error/scene file could not be loaded. I rendered the same file but took out the render instances (making the file around 700 mb) and it worked fine. Not good because without the render instance objects, my scene is pointless.
    Is there a limitation? Am I crashing Net Render or possibly does net render time out before the scene has a chance to load? Thanks.
    Kevin Cook replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
