Activity › Forums › Maxon Cinema 4D › Net Render Error
  • Net Render Error
    Posted by Mike Scott on April 30, 2011 at 7:18 pm
    I have setup everything as I should with my server/client prefs. I have made a folder for rendered files. I have “Saved Project” in order to have textures. when I start job, it splits up the frames to the 3 clients and then errors out “Missing Texture/low memory” The texture is an HDRI file from the content browser that’s in the tex folder, so that doesn’t make sense. The Low memory message puzzles me, as I know the 3 boxes I’m using have ample ram and processors. I don’t have the exact specs with me because I’m offsite today. If anyone has an opinion or idea about this I’d appreciate any input. I’d really like to increase my render speed with this great resource.
    Jason Linn replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jason Linn
    May 4, 2011 at 12:16 am
    From the sound of it, it seems that the texture isn’t being referenced properly from the saved/uploaded cinema file.
    I’m thinking three possibilities…
    1. the .hdri reference within the project is not the same as the one being uploaded to netrender
    2. you are uploading the wrong hdri file
    3. check to make sure that you save “project” and that when you imported the hdri that it copied to that directory as well. (not just referenced)
    just my first impression. Sounds like the connection between the texture/file/netrender reference is off somehow.
    good luck,
    J
    https://www.jasonlinn.com
