Activity Forums Maxon Cinema 4D Net Render and Plug-ins
  • Net Render and Plug-ins
    Posted by Don Holland on August 1, 2009 at 3:26 pm
    Where do you install the plug-ins for the net render clients? I have Net Render Client and Plug-ins folder all contained in a folder called maxon. When I go to the plugins menu in Net Render Client it says “empty”. I’m on a several Macs. 2 G5’s and a MacPro if that matters.
    Don
    Claude Johnson replied 12 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Tim Shetz
    August 1, 2009 at 6:58 pm
    I haven’t done it with v11 but with 10.5 and 10 you run the Cinema 4d Setup on the machine with the client and JUST install the modules or plugins. It should put them in the correct location. You have to do it on each machine that you want to run a client.
  • Don Holland
    August 1, 2009 at 7:21 pm
    Thanks Tim,
    But I’ve already done that. I guess I can try uninstalling everything and installing it agaain.
  • Tim Shetz
    August 1, 2009 at 7:31 pm
    Hmmmm that’s weird. What version of C4D are you using? Are these the standard Things like Mograph and such, or third party plugins?
    Tim
  • Tim Shetz
    August 1, 2009 at 7:39 pm
    I just checked on some of my machines that just have the client installed. The directory structure should look like:
    MAXON
    NETrender
    clientprefs
    Exchange Plugins
    library
    manuals
    modules
    plugins
    resource
    results
    scene
    tex
    all of my things like advanced render and Mograph are in the modules folder.
    Tim
  • Richard Rose
    August 15, 2009 at 3:13 pm
    I”m encountering the same issue – was there any resolution? Thanks,
    Rich
  • Tim Shetz
    August 15, 2009 at 6:01 pm
    Have you run the plug-in or module installation on every machine you want to use as a client? Doe your structure look like the one I previously posted?
  • Don Holland
    August 16, 2009 at 3:48 pm
    I have all the Plug-ins installed correctly on all machines. It looks like its the fault of one spcific plug-in. PoserFusion for Cinema 4D does not work with Net Render. I haven’t received official confirmation from Poser (I’ve left several emails), but when I make a file without using the PoserFusion plug-in. It works.
  • Tim Shetz
    August 16, 2009 at 6:46 pm
    Wow…if you get confirmation from them directly and you respond to this post and let us know for sure so it’s in the archive?
    Tim
  • Claude Johnson
    January 5, 2014 at 2:42 pm
    5 years later –
    Did you get an answer? Because I have the same problem. It renders on the Server Client. But on the client of the outside computer the PowerFusion Object is not render, but the Native C4D objects are. I’m on C4D R11.5. Team Render doesn’t seem to work either with PowerFusion Objects on R15. It crashes the C4D on the external computer with a Crash log
    Mac Mini, OSX 10.9.1, Vue 8 xStream, modo 401, C4D 15
    https://www.claude3D.com
  • Claude Johnson
    March 9, 2014 at 1:34 pm
    After a few exchanges with Smith Micro, I had it worked. The main problem is where you put your files. If you use InterPoser Pro it’s a lot easier,
    https://www.claude3d.com/claude3d/Net_Render_for_C4D_with_Poser.html
    It should be the same with Net Render and Team Render.
