Activity Forums Maxon Cinema 4D Net Render
  • Net Render
    Posted by Alfred Schmidt on April 28, 2008 at 10:31 am
    I am considering buying Maxon’s Net Render Module, there does not seem to be much info on the net about its usage, so if anyone has experience using it please share your opinion on it.
    Thank you all any replies.
    Adam Trachtenberg replied 18 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 28, 2008 at 10:50 pm
    It’s pretty simple to use and for the most part works well. It works through your web browser. You set up the host program on one machine and the clients on your other other machines. Fire up the html-based interface and you have the option to load jobs/files and to add them to your queue. Another page will show you what frames are assigned to the various clients and what progress they’re making. It also shows a thumbnail of the last frame rendered for each client. The results are collected on the host machine.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
