Net Framework possible problem
Posted by Paul Gregory on February 9, 2009 at 1:02 amWhen I try to start up Vegas 6, I keep getting an unknown error message. From what I have seen on forums I suspect that this might be something to do with Microsofts Net Framework which I understand is a prerequisite for running Vegas. I did a check to see what versions that I have installed as suggested by Microsofts web site. It seems that I have versions 1.0.3705, 1.14322 & 2,050727.
Windows update is now suggesting that I need version 3.5.
Do I really need this or would I be better of deleting or reinstalling the previous versions?
Thanks in advance
Paul Gregory replied 17 years, 7 months ago 3 Members · 8 Replies -
Harold Brown
February 9, 2009 at 2:02 amFor Vegas 6 you need .net framework 1.1
https://www.sonycreativesoftware.com/download/netframework.asp
Harold
__________________
http://www.BhagaVideo.comCheck out my published DVDs at
http://www.edellismagic.com/Previews.html -
Paul Gregory
February 9, 2009 at 4:02 amDoes this mean that I should try to delete version 2? I had thought that like most programs that these updates were accumulative.
Thanks in advance
John Rofrano
February 9, 2009 at 6:00 pm> Does this mean that I should try to delete version 2?
Only if you have no other programs that require it. Vegas 6 does not.
Not only are the not cumulative but they are not upward compatible either meaning you can’t run .Net 1.1 programs on 2.0; you need to still have 1.1 installed.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Paul Gregory
February 9, 2009 at 11:43 pmThis being the case then I should not have to uninstall version 2? If this is true then my problem must stem from elsewhere.
Thanks in advance
Harold Brown
February 10, 2009 at 1:17 amJust load 1.1 and don’t worry about the other versions.
Harold
__________________
Paul Gregory
February 10, 2009 at 5:48 amI used Windows delete programs to remove Net Framework 2, then restarted Windows. The first message that I get is that Net Framework 2 is required to run ATI Catalyst Control Center. That is a program that I’m unfamiliar with but suspect that it has something to do with my graphics functions.
I thought that I would see if this fixed the Vegas problem but once it tried to open Vegas I got the message that ‘an error occurred when starting Vegas, the reason could not be determined.’ I then click the OK button & the box disappears. Whether or not I going to have a problem running Vegas like this I have no way of saying. Any ideas?
Thanks in advance
John Rofrano
February 10, 2009 at 12:20 pmThe .Net Framework is simply a run-time library that sits on your hard drive until some application uses it. It does not actively run on your computer and there is no harm in installing it. I would install .Net 1.0, & 1.1 for Vegas, and 2.0 for ATI. Then see if that clears up the problem. If not, re-install Vegas 6 now that all the .Net software is re-installed.
~jr
Paul Gregory
February 12, 2009 at 12:05 amAs stated I had deleted Version 2. After the last suggestion to used Windows update to get version 2 again. It said that it downloaded, but then says that it can’t be installed, no reason given. If I go to add/delete programs in control panel it shows as installed. If its really installed it hasn’t installed in a way the prevents the ATI error message. I guess that this is just all a Windows thing.
Thanks in advance
