Activity Forums Apple Final Cut Pro Legacy nestled sequence changes
  • nestled sequence changes
    Posted by Robyn Symon on December 27, 2006 at 8:43 pm
    Hi. I’m trying to make changes in a nestled sequence such as changing a super but the changes are not being reflected on the master sequence.
    The old super remains. Any ideas why. Also, when doing a lower third title, the title appears to shift. Thanks!!
    Sam Zimman replied 19 years, 8 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    December 28, 2006 at 4:23 am
    Try double clicking the nested clip to open it’s sequence. Change the title there… it should be reflected in the sequence then.
    Maybe if you post more about the lower third problem? Which tool did you create them with? Title 3D or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Boyd Mccollum
    December 28, 2006 at 4:42 pm
    After you update your nested sequence – you need to force update the nest in your master (or parent) sequence. The easiest way is to turn on clip overlays (opt+W), then drag the opacity of the nest to 0 then back to 100. Then rerender. The reason to do this is that the parent sequence reads the render file of the nest, not the contents of nested sequence itself, so you need to break the link to the render file so you can rerender it.
  • Sam Zimman
    December 28, 2006 at 7:24 pm
    I also like to toggle “Clip Enable” ctrl+B
