Activity › Forums › Adobe Premiere Pro › Nesting workflow
  • Nesting workflow
    Posted by Vince Becquiot on August 9, 2006 at 7:34 pm
    Something I came accross in AE, but never in Premiere…
    Working on a (boring) presention, video + slides. I’m doing a simple dissolve between slides and video at client request.
    I had to add a template on top and shrink the slides to compensate for the safety margin. It is basically a header and footer, with alpha channel in the middle for the slides.
    So I have to nest these 2 because of the usual blending issue arising when dissolving 2 separate layers at the same time. (No easy way to Photoshop merge the template here for 200 slides).
    My question concerns the workflow for those of you who have a done a lot of these (I feel sorry for you ;). Should I just work without transitions until the end, and then put the slide + template tracks into a new sequence, and then apply the transitions, or it there a better way ?
    Vince
    Steven L. gotz replied 20 years, 1 month ago 2 Members · 1 Reply
  • Steven L. gotz
    August 9, 2006 at 8:20 pm
    I always edit as though I don’t need to worry about the safty margin. Then nest that sequence and crop it. Or scale it down.
    Steven
    https://www.stevengotz.com
