Activity Forums Avid Media Composer Nesting Spectramatte with BCC Drop Shadow
  • Nesting Spectramatte with BCC Drop Shadow
    Posted by John Lafauce jr. on October 21, 2008 at 11:10 pm
    Does anyone know of a painless way to use BCC Drop Shadow with a Spectramatte keyed foreground to cast a drop shadow on a background? I know Spectramatte allows you to remove a shadow on a greenscreen, but I actually want to add a shadow. All suggestions or workarounds appreciated.
    John
    Andy Crow replied 17 years, 11 months ago 4 Members · 4 Replies
  • Jon Zanone
    October 22, 2008 at 11:51 am
    Can’t you add a shadow in spectramatte? I thought it was toward the bottom of the effect pallette, in one of the twirly triangles….
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Terence Curren
    October 22, 2008 at 1:15 pm
    You can always promote the Spectramaate to 3D to get Avid’s built in shadow. It’s not very good though.
    Or, use the BCC chroma key.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • John Lafauce jr.
    October 22, 2008 at 2:43 pm
    Thanks for the feedback. You would think that once an alpha is generated (resulting from the key), that matte can be nested with BCC Drop Shadow to create a shadow. The limitation appears to be that Avid is not passing off the alpha to other effects.
  • Andy Crow
    October 22, 2008 at 5:41 pm
    This can be done, but it must be done manually. Get your Spectramatte key the way you want it and then select “Show Alpha”. Alt-apply your BCC Drop Shadow effect as normal and select “Apply to Title-Matte and Invert Matte”. Then, step into the BCC Drop Shadow effect and on the layer underneath the Spectramatte key edit in your original source footage. There will be three layers underneath the effect. The top is the Alpha, the middle the source, and the bottom the background. Then step back out of the nested effect as normal.
    It also important to remember for this effect to work you’ll need to have an empty layer between your nested effect and your background layer.
    ac
