Activity › Forums › Adobe Premiere Pro › Nesting sequences and surround questions
  • Nesting sequences and surround questions
    Posted by Trevor Asquerthian on July 30, 2008 at 8:26 am
    1. Any way of editing sequences into other sequences without nesting? (default behaviour in Avid, cmd + insert/overwrite in FCP). I realise the appeal of nested sequences, but sometimes want to have the original clips edited into my sequence.
    2. Any way of targetting more than 1 video / 1 audio track in a sequence? It seems not according to the manual.
    3. Related – whilst I can load a sequence with multiple tracks into the source monitor there is neither a source track panel (if I wanted to patch A3 to A1 for example) nor a source timeline view (so I can view that sequence’s timeline without loading it on the programme side).
    4. Whilst trimming (trim monitor) there is no indication of where the current time indicator (‘nowline’) is as I preview the trim – or am I missing a setting?
    5. Any way of making a track LFE only? I can use the puck and centre/LFE volume knobs to route to the other 5 tracks, but can’t seem to isolate a feed to the .1 only
    6. Is there a keyboard shortcut equivalent to clicking in the current time box (so I can move around the timeline with absolute and relative timecodes) – a go to command. I can’t find this in the help.
    7. Is there an ‘extend’ command (like Avid/FCP) or do I have to roll an edit to acheive this?
    Many thanks
    Trevor
    Trevor Asquerthian replied 18 years, 1 month ago 2 Members · 2 Replies
  • Dave Friend
    July 31, 2008 at 1:07 pm
    Trevor,
    I can address some of your questions.
    [Trevor Asquerthian] “1. Any way of editing sequences into other sequences without nesting? (default behaviour in Avid, cmd + insert/overwrite in FCP). I realise the appeal of nested sequences, but sometimes want to have the original clips edited into my sequence.”
    You can copy and paste multiple tracks/clips from one timeline to the other. There is an insert paste command but I cannot remember the keyboard command for it (maybe ctrl+shift+v?). It is also available in the main menu under Edit.
    [Trevor Asquerthian] “2. Any way of targetting more than 1 video / 1 audio track in a sequence? It seems not according to the manual.”
    No. Really annoying isn’t it?
    [Trevor Asquerthian] “3. Related – whilst I can load a sequence with multiple tracks into the source monitor there is neither a source track panel (if I wanted to patch A3 to A1 for example) nor a source timeline view (so I can view that sequence’s timeline without loading it on the programme side).”
    Patching is pretty much non-existent. When using a sequence as a source clip you only get the mixed output of that sequence not the individual tracks.
    [Trevor Asquerthian] “7. Is there an ‘extend’ command (like Avid/FCP) or do I have to roll an edit to acheive this?”
    There is, but I don’t remember what it is because I never use it. The reason? It doesn’t function all that well. Certainly does not behave as well as the Avid or FCP equivalents. I gave it up in frustration and usually just use the roll (or other) trim tool instead.
    Dave
  • Trevor Asquerthian
    July 31, 2008 at 6:16 pm
    Thanks for that
