Activity Forums Apple Final Cut Pro Legacy nesting sequences and audio problem
  • nesting sequences and audio problem
    Posted by Eric Holzapfel on April 22, 2010 at 4:45 pm
    Hello Forum Members,
    I think my question is somewhat basic.
    I have several sequences with various audio tracks. I want to
    put each sequence in a “master” sequence. So far this has worked fine.
    I have one sequence that has 12 audio tracks. The audio levels, etc
    are fine when I play the sequence in the view/timeline. When I drag the sequence into the master sequence, the audio plays fine up to a point, and then the level cuts down alot, and then returns to the correct level.
    I have tried raising the level in the “child” sequence, but that seems not the way to do things. Any tips or suggestions on how to get the audio to play correctly in the sequence where I nest it? The audio tracks are aif tracks, etc.
    Eric
    Eric Holzapfel replied 16 years, 5 months ago 2 Members · 2 Replies
  • John Fishback
    April 22, 2010 at 7:15 pm
    Try doing what FCP calls a Mixdown: Sequence Menu > Render Only > Mixdown
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Eric Holzapfel
    April 22, 2010 at 8:41 pm
    Hello John,
    I will do that. Thanks.
    Eric
