Activity › Forums › Apple Final Cut Pro Legacy › Nesting Question
  • Nesting Question
    Posted by Max Frank on May 16, 2007 at 8:00 pm
    Let’s say a person cuts a 10″ clip out of an hour-long nested sequence and places that clip onto a another timeline.
    The, he wants to open that 10″ nested sequence, and when opened, he wants to reveal ONLY those 10″ of footage [ie, and not the entire hour-long sequence that was nested].
    Is that possible?
    And if so, how?
    I hope this makes sense.
    Thanks in advance,
    Wayne
    Max Frank replied 19 years, 4 months ago 3 Members · 4 Replies
  • Walter Biscardi
    May 16, 2007 at 8:05 pm
    [Wayne K 123.] “Is that possible?
    And if so, how?
    I hope this makes sense.”
    You need to make a second nest of that chunk you cut out.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Max Frank
    May 16, 2007 at 8:19 pm
    Walter,
    Thanks for the prompt response.
    I tried your suggestion – but when I open the re-nested sequence, it shows me the 10″ piece I had nested previously.
    What I’m trying to do is see the SOURCE material from the originally nested sequence, but ONLY that 10″ section I had cut out.
    I fear I may not be communicating as effectively as need to, but I hope this makes sense.
    Wayne
  • Bret Williams
    May 17, 2007 at 3:05 am
    Open the new nest, copy the 10 minutes you want. Paste into a new nest. Edit the new nest into your sequence or wherever you want.
    A nest is just like a clip. Just because you cut it up or out doesn’t make the rest of the clip/nest disappear. If you want a nest of just the 10 minues, you have to create a new nest of the 10 minutes.
  • Max Frank
    May 17, 2007 at 8:17 am
    Thanks all for the reply — from what I’m hearing, it’s not possible to do what I need.
    Wayne
