Activity › Forums › Apple Final Cut Pro Legacy › Nesting Problems with Alpha Channels
  • Rafael Amador
    February 21, 2009 at 2:10 am
    [Jeremy Browe] “Afterwards I nested the 3 layers together and pasted the new nested sequence into a test sequence on V2 and set the composite mode to Travel Matte Luma and my original color footage to replace the white in the nested footage on V1 and set the travel matte to alpha.”
    Jeremy,
    Again, you need to inverse the order. The mask have to go always underneath.
    Put the nested sequence in V1.
    Set the footage in V2 and in Travel Matte Luma mode.
    rafael
    http://www.nagavideo.com
