Activity Forums Adobe Premiere Pro Nesting layers
  • Nesting layers
    Posted by Butch Mcdonald on August 15, 2006 at 6:44 am
    If I have 10 layers in a sequence and want to nest five of them, do I have to create a new sequence and drag the five layers into the new sequence then drag the new sequence back into the original sequence? Seems a bit clunky if this is the only way. Why wouldn’t it be designed to work like sub comps in AE?
    Hopefully there is another way.
    Cheers
    Butch
    Vince Becquiot replied 20 years, 1 month ago 2 Members · 1 Reply
  • Vince Becquiot
    August 15, 2006 at 5:55 pm
    I believe that may be the only way, no shortcut that I know of.
    I just do a shift + track select tool to select all the tracks I need, then copy and paste in a new sequence.
    It is clunky… unless somebody comes up with that miraculous workaround.
    Vince
