Activity › Forums › Adobe Premiere Pro › Nesting in premier
  • Nesting in premier
    Posted by Nathan Kendall on February 10, 2017 at 7:27 pm
    I set a clip to nest and applied warp stabilize. I got a message stating warp stabilizer needs dimensions to solve nest footage……
    I added warp stabilizer to the nested timeline. I keep deleting and creating new nesting. this time it nested footage and shows in green in original sequence but not the new sequence that is suppose to be nested.
    11038_nested.png.zip
    Jon Doughtie replied 9 years, 7 months ago 2 Members · 1 Reply
  • Jon Doughtie
    February 10, 2017 at 7:51 pm
    Warp Stabilizer can be a peculiar animal. I will usually isolate the shots I want to stabilize, render the individual shots to see if I like the result, then export to a non-lossy codec so the effect is “baked in”. I’ll import those “baked-in” shots to my project and work with them in the edit.
    Warp Stabilize is pretty much the only time I do this routine. Just simpler in the long run for me.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
