Activity Forums Apple Final Cut Pro Nesting CompoundClips and Secondary Storylines -what are the rules?
  • Nesting CompoundClips and Secondary Storylines -what are the rules?
    Posted by Jim Bachalo on June 26, 2014 at 11:06 am
    Ok, my first major project involving nested Compound Clips and I’m going a bit wonky.
    My understanding is that you can Create Compound Clips out of anything in your project. And that Compound Clips can contain Compound Clips which can contain….
    so
    CompoundClip > CompoundClip > CompoundClip >CompoundClip etc
    Sort of like PreComps in AfterEffects…
    Secondary Storylines can’t directly contain other Secondary Storylines, BUT, you can create a Compound Clip from a Secondary StoryLine, which in turn can be turned into yet another Secondary Storyline, etc
    so
    SecondaryStoryline > CompoundClip > SecondaryStoryline > CompoundClip etc
    Am I correct so far?
    The logical question is, how many levels deep can-should you nest and, what are the performance penalties with increased nesting?
    You should follow me on Twitter here. My latest work
    Jim Bachalo replied 12 years, 2 months ago 2 Members · 2 Replies
  • Jari Innanen
    June 26, 2014 at 8:03 pm
    Compound inside compound spells trouble. I hardly ever use compound clips. So don’t if not necessary.
  • Jim Bachalo
    June 26, 2014 at 8:42 pm
    So only use Compound Clips if absolutely necessary?
    I’m still a FCPX novice but I would imagine its pretty difficult to have a project thats even remotely complex without making use of compound clips, or perhaps I’m not making good use of Roles, etc
