Activity Forums Avid Media Composer Nesting Clips on the Timeline
  • Nesting Clips on the Timeline
    Posted by Jonathan Briggs on July 25, 2008 at 6:54 pm
    Hi there
    I have a ticker-tape type effect which uses 3 vid layers (text and graphic), which needs to be moved up into title safe – is there anyway to collapse or nest these down into one video layer/or sequence whilst retaining the alpha channel?
    If not – is there any way to move several clips by the same amount simultaneously?
    Many thanks in advance
    Jonny
    Jonathan Briggs replied 18 years, 1 month ago 2 Members · 2 Replies
  • Accountfrozen_needs_realname
    July 25, 2008 at 8:53 pm
    Select the tracks you want to collapse in-to-out. Click the collapse button; it should be on the toolbar just above the timeline.
    Your three tracks will collapse into one. If you want to get to the individual tracks again, just step into the nested tracks.
    Search “collapse” in the help for more information.
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
  • Jonathan Briggs
    July 25, 2008 at 10:29 pm
    Many many thanks!
    Jonny
