Activity Forums Apple Final Cut Pro Legacy Nesting and un-nesting a sequence
  • Nesting and un-nesting a sequence
    Posted by Ed Stevens on August 29, 2005 at 11:46 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I believe I have the stock display card
    When you nest a sequence, it nests the original, not the new name you give the sequence.
    e.g. I have a sequence names video 1. I sequence with the name video 1N. The unsequenced is video 1N. and the sequenced is video 1.
    Shouldn’t it be the other way around?
    Also how do you un-nest a sequence?
    ED
    Ed Stevens replied 21 years ago 3 Members · 4 Replies
  • Rajesh Bhanushali
    August 30, 2005 at 12:26 pm
    Hey Ed,
    When you nest the sequence “A” ,it asks for a name & suppose u give the name A1,
    Then the Nested sequence is named “A” & the Un nested is “A1”
    Well this is the way it is in FCP 🙂
    To unnest the sequence Double Click on the nested sequence “A” & the A1 sequence will open
    in the timeline, whatever changes you do in A1, the same will be available for you in “A” i.e your
    nested timeline.
    Hope the same is helpful in some way 🙂
    Regards
    Raj…
  • Tom Wolsky
    August 30, 2005 at 12:50 pm
    This is not correct. There are two ways to make a nest. You can bring one sequence from the browser into another and it retains the name you gave it in the browser. You can also nest clips within a sequence, which is when FCP asks you to name the sequence. If you name it 1N that’s the name that appears on the nested sequence inside the master sequence. That’s also the name that appears on the new sequence that appears in the browser.
    “When you nest the sequence “A” ,it asks for a name & suppose u give the name A1,
    I have no idea what this means, but unless you’re doing something truly bizarre this doesn’t happen. When you bring a sequence from the browser and place it in another sequence, the function called nesting, FCP does not ask you to name the nested sequence. The only time it asks you to name a sequence if when you nest clips within a sequence. If you already have a nested sequence inside a master sequence, and then select it and choose Sequence>Nest Items, it will ask you to name the nest, and the new nest will have the name you give it. But why you would want to do that I cannot for the life of me imagine?
  • Rajesh Bhanushali
    August 30, 2005 at 1:39 pm
    Thnx for the correction TOM
    Raj…
  • Ed Stevens
    August 31, 2005 at 3:34 pm
    Thanks all for the great info
    ED
