Activity › Forums › Adobe After Effects › Nesting a comp… but I want it to loop!
Posted by Adrian Le roux on March 9, 2011 at 7:54 amHi ya…
I know how to do an animation in a composition… then I know how to add that composition to another composition (nesting)…
But I really need to be able to LOOP the original composition so that it keeps going in the NEW comp.
Make sense?
Cheers and appreciate your time.
a
Pax Webb replied 9 years, 6 months ago 5 Members · 9 Replies -
Joey Foreman
March 9, 2011 at 11:04 amApply Time Remapping to your nested comp. Option-click the Time Remapping stopwatch, hit the Expression Language Menu icon (the 4th little icon), go to Property, and select the Loop Out expression:
loopOut(type = “cycle”, numKeyframes = 0)
Or you can just copy the expression above and paste it into the expression field.
Be sure to extend your layer duration afterward.
Joey Foreman
Editor/Compositor/VFX Artist -
Andrew Devis
March 12, 2011 at 8:22 amHave you tried the loop option in interpret footage?
Andrew… because it’s all about stories …
Joey Foreman
March 12, 2011 at 2:19 pmI don’t know if things have changed in CS5, but Interpret Footage has only ever been available for footage, not compositions.
Joey Foreman
Joey Foreman
March 22, 2011 at 1:15 pmAs soon as you option-click the stopwatch for Time Remapping, you’ll see it appear to the right in the timeline. The word timeRemap will be highlighted in blue. At that point you can paste (command-v) the expression, or type it out.
Joey Foreman
Joey Foreman
March 22, 2011 at 1:28 pmhttps://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7a2ca.html
Joey Foreman
Pax Webb
March 1, 2017 at 6:42 pmThanks, works great for me, except I always get a blank frame (from the overlaid composition) at the very end of the first loop (or maybe its the first frame of the second loop). Interestingly the blank frame does not reappear for the rest of the project (with dozens of loops). Please note that the whole project doesn’t blank out on that frame, just the composition on the top layer, and just for that one frame of the whole project. Any ideas?
