Activity Forums Apple Final Cut Pro Legacy Nested sequences, when made longer, change the sequence they’re nested in.
  • Nested sequences, when made longer, change the sequence they’re nested in.
    Posted by Dominik Bochenski on May 20, 2005 at 5:23 am
    The manual does say how to work around this… unfortunately, I don’t get it. Short of placing splices in a nested sequence, what workflow do you use for it not to be affected when changes are made in the source.
    I hope this makes sense, I’m tired.
    Dominik Bochenski replied 21 years, 4 months ago 2 Members · 4 Replies
  • Pdr
    May 20, 2005 at 10:05 am
    Hi
    I’m not sure if I understand the question — do you want you nested sequence to NOT reflect changes made in the source sequence?
  • Dominik Bochenski
    May 20, 2005 at 3:39 pm
    Yes, you’re right. I don’t want the changes to be reflected in the ‘MASTER’ sequence that has all the little sequences nested inside of it. Don’t get me wrong, I see the huge benefit of this feature as well. I just want a good workflow method to get around this when I don’t want those changes to be reflected in the MASTER.
    For example, if I have a dessolve between one nested sequence and another and I want to make the dissolve longer. I would have to go into the nested sequence, make it a little bit longer, giving it the handles I need for the dissolve. Unfortunately, when I go back to the master, my whole timeline has been shifted, music sync and all.
  • Pdr
    May 20, 2005 at 3:55 pm
    Ok, so if you don’t want the master sequence to be changed when you make changes to the subordinate sequence, then don’t nest them; use good old copy (cmd-C) and paste (cmd-V).
    eg. SeqA + SeqB = SeqC
  • Dominik Bochenski
    May 20, 2005 at 4:02 pm
    Hold on now…. A little misunderstanding. I ‘DO’ want the changes to be reflected…. just not the length of the ‘MASTER’ sequence.
