Activity Forums Apple Final Cut Pro Legacy nested sequence/banding.. still
  • nested sequence/banding.. still
    Posted by Andwon on August 27, 2007 at 10:18 am
    why do i get banding and image degradation when a nested sequence is scaled down (viewed on a monitor)? all sequence settings (dv pal) match the settings of the clips in every way. a kona 3 is feeding the monitor via it’s component outputs.
    the footage:
    digibeta captured via firewire as dv
    the nested sequence:
    1 layer .tga file w/alpha
    1 layer video at 100% scale
    1 layer matte
    the system:
    Mac Pro Dual Core
    Kona 3
    FCP 6
    it no make sense
    – andwon in frustration
    Chris Borjis replied 19 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 27, 2007 at 12:50 pm
    You’re getting banding and quality issues for two reasons:
    1. You’ve captured into an 8 bit format (DV)
    Capturing in 10 bit formats makes a lot of banding issues go away.
    2. You then made it worse by scaling it. However if you check on the “Best” quality in the Motion Filtering settings of the Sequence settings’ Processing tab, you might get a better looking result.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Chris Borjis
    August 27, 2007 at 3:31 pm
    [Jerry Hofmann] “However if you check on the “Best” quality in the Motion Filtering settings of the Sequence settings’ Processing tab, you might get a better looking result.”
    As odd as it seems, I have found you get better quality if its set for Fast.
    Makes no sense at all.
