Activity › Forums › Adobe Premiere Pro › Nested sequence
Nested sequence
Posted by Brian Barkley on May 30, 2010 at 6:35 pmAfter rendering, my nested sequence is black. Why?
Sikter Hajvan replied 16 years, 3 months ago 4 Members · 6 Replies -
Brian Barkley
May 30, 2010 at 8:03 pmWell, I highlight video layers and select “nest” … everyhing is now one track … great … but when I render it, the sequence goes black … why?
Sikter Hajvan
May 31, 2010 at 1:50 pmWhen I do “Nesting” I drag wished Sequence from project window to my master sequence, right click on it and select NEST. Works every time and I use it a lot, specially when I want to put touch of after effects on entire nested seq. (Works even if I split it and put effects on particular parts nested seq.)
Hope it helps
I know there is a possibility to nest just a clips but I didn’ have need for that yet
Alex Udell
May 31, 2010 at 8:38 pmSikter,
Nesting refers to treating several elements as one collapsed clip.
Simply the act of placing the sequence on a new timeline as a clip is already nesting. There is no need to nest that clip. You are actually double nesting when you do that.
Alex
Sikter Hajvan
May 31, 2010 at 9:14 pmThanks Alex,
I realised that after I posted my last post.
You remember when I asked what was I doing wrong because I got additional sequnce to render. Another mistery solved
