Activity Forums Apple Final Cut Pro Legacy nested sequence names not changing
  • nested sequence names not changing
    Posted by Bleakley Mcdowell on November 20, 2014 at 4:37 am
    I’m working on a timeline with lots of nested sequences. If I change the name of a nested sequence in the browser, it isn’t reflected in my timeline – the nested sequence seems to have lost its connection to the browser. For some nested sequences, if I choose “reveal master clip” FCP tells me nothing is found. But, I can see the sequence right there in front of me and can edit just like any other sequence, it just isn’t in the browser…. The only place it seems to live is within the timeline it is nested in.
    This doesn’t make any sense to me. I want to be able to nest sequences and still have them be referenced in the browser.
    Anyone have this problem before?
    B
    Shane Ross replied 11 years, 9 months ago 2 Members · 4 Replies
  • Bleakley Mcdowell
    November 20, 2014 at 4:42 pm
    Hi Dave,
    Thanks for the the response. I do rename the sequences before I nest them in the timeline, but what if I then want to rename them again? This is occurs often.
    I double click on a nested sequence in a timeline to edit it, but once I’ve made edits it is no longer referenced in the browser. And if I make changes to the sequence in the browser they are not reflected in the nested sequence in the timeline – even when they share the same name and were originally the same sequence?
    Is this just the way things are in FCP? it goes the other way too – the edits made to a nested sequence via the timeline are not reflected in the sequence in the original sequence in the browser.
    Does Premier work this way too?
    Blake
  • Shane Ross
    November 20, 2014 at 7:32 pm
    What Dave said. Nesting is to be used sparingly, and only if the segments in those nests are locked…no further changes being done. Because they don’t always work as designed and advertised. They are dangerous things that can get you into big messes. When you get to the color correction phase, they really mess things up. I always say avoid nesting. There is no real good reason to do it. It might seem like there is, but that’s only if you never color correct, and if you don’t want to make changes to the sequences they represent.
    Shane
    Little Frog Post
  • Bleakley Mcdowell
    November 20, 2014 at 8:37 pm
    Ugh. Ok. Thanks.
    Yes, they certainly don’t seem very useful at all with the way they work, which is a shame because it could, in theory, be a nice way to edit.
    Blake
  • Shane Ross
    November 20, 2014 at 8:47 pm
    FCX implemented them better…calling them “auditions.”
    Shane
    Little Frog Post
